can i mount my winch this way
Wildcat
Overlander Wannabe
winch is mile marker sec8. if i mount it with the feet pointing down, the control box is too tall where i want to mount it. i guess i can move the box and make longer cables.
question is. can i mount it with the feet facing forward? it would be pulling from the “bottom” instead of the “front”.
is it safe to mount feet forward or should i just relocate the box?
As long as you keep the drum rotation the same you can mount it foot forward. You must still use all 4 mounting bolts. The gear box is also clock-able to put the clutch lever where you want it. I would mount the winch where it makes the most sense for access and strength. For solenoid box it should also be in a good spot,having to crawl is the mud to connect your controller or free-spool is not fun. Build it so its easy to use in the future.
It's arguably better because the mounting bolts are not exposed to shear (but I'm no engineer!). As long as the vertical part of the mounting bracket is as solid as the horzontal one it should be fine.
For the “feet forward“ mount one thought would be to reorient the relay box back to the original vertical position. Would provide I think better protection from water/dust intrusion, easier access for inspection & service.
having the control box to the back or off is the reason im even asking this question. the box interferes with the bottom of the radiator.
thanks for the responses. im going to start my cardboard aided design soon.
You might have already finished your project... I mounted one in a tight place and just relocated the box controller where it was convenient.
Yes you can do this. it is no problem at all (older ARB bumpers for example required the feet forward on all winches). You can rotate the gearbox and even the motor to match.
The control box is easy to relocate with longer and it is suggested. Just get proper covers for the motor terminals and you should be ok.
M meadow build
