DiscoveryXD
I'm trying to replace the front output shaft bearing on my t-case and the darn bearing won't come off the shaft. The shaft and the bearing slide in and out of the housing, but I'm afraid to pull the shaft all the way out cause I don't know if it's supporting anyhting inside? If I pull the shaft out, will I be able to slide it right back in, or will I screw myself and need to take the thing apart to get the shaft back in?
If I use a slide hammer, the shaft is still going to come with the bearing....
