CoastalDefender
Who does it here? I did it a few times in summer camp when I was a young lad. But not since then.
Until today.
I got this canoe last spring, and was so busy with work that I never got around to getting a PFD or actually getting out there and just doing it.
I also got a decent PFD. Though I'm a strong swimmer, I found it supremely dangerous and stupid to go out into the ocean without a PFD on at the least. So I have been holding myself back from doing it in this great weather we've had, until my PFD showed up on Tues.
So, I've got a Coleman (Pelican) 16' canoe in firecracker red, two Scepter water cans full of water for the front (ballast), my daypack, PFD, 20' nylon line, GPS, and a paddle.
I need a bit more ballast up front, I was uneven in the water. I'm thinking 50lbs more, and it will be perfect.
I launched and paddled for two hours against current from Elk River to John's River (both in Grays Harbor). I didn't do my GPS correctly when I started off, but I estimate it was anywhere from 4-6mi.
I have to be honest, it was a spur-of-the-moment because work was only 3hrs today, and it was such a beautiful day, and I had the time. The tides were also in my (mostly) favor.
So I started out just getting a feel for the canoe, saw how it handled in the water and what I could expect out of it. I attained a 6mph with-current speed, and a 2mph against-current speed. I prefer with-current, but with the tide going out, I ended up being against-current all day.
Few things I learned-
-Unevenly loaded boat makes it more difficult to steer.
-River mouths are very tricky to navigate. The conflicting currents really throw the boat around.
-Take more water than you plan on consuming. Like 3x as much.
-I need a foam seat or something. The 36 degree water made my rear numb within the first 30min.
-I need dry-bags for my gear. It didn't get terribly wet, but I was certainly concerned about a tipover and losing it all. Dry-bags appear to not be cheap.
-I am going to be taking two or three paddles from now on. At one point it occured to me that if my paddle broke, I would be SCREWED, and most likely require rescue/tow from the USCG.
-I am going to dummy-cord the paddles and my ankle to the boat with some 550 cord. Why not, right?
I am so whooped right now. My upper body is destroyed. I loved every second of it, and can't wait to go back out there again.
*An extremely regional note of some significance- The waters out in the Harbor are so shallow, that just a drop of a few inches during low tide exposes hundreds of yards of mudflats and shore. You really need to be aware of the tides and where you are in the Harbor before you go out in it. Even when I was 4-500ft off teh shoreline, I was no more than 2ft deep waters. Often I would scrape paddle on the bottom, and that would lead me to put more distance between me and shoreline.
I quickly learned the difference on the surface of the water of how deep the water was underneath it. It's best to find yourself in the deepest part of the river/channel/harbor. No sense in getting stuck somewhere you can't leave until high tide.
Until today.
