Canter tyre questions
nicknoxx
Two quick tyre questions, I'm considering the benefits of a single rear wheel conversion. . .
1. What is the largest tyre that can be fitted to the twin rear wheels?
2. What is the largest tyre that can be fitted to the front wheel without altering any bodywork?
Thanks
Aussie Iron
For duals you can possibly get away with 900/16s as long as you don't deflate. 8.25/16 may be alright if not to much air is let out.
I'm running 325/75x16 on the front and they don't interfere with the guards (but i am lifted a bit). 9.00/16 are just a bit smaller than 3.25/75x16.
Dan.
steve4wdaus
4WDaus "tralia"
Also need to know how much weight is over the rear axel. The range of tyres for truck below 4.5t is far wider than above.
Decanter
Why does this site often upload pics in the wrong orientation? Does anyone know? I see it and have experienced it often. This is one of the reasons I've posted more build pics on another format. This site can be a PITA to make it look good.
Bris31
Assuming you are taking photos with a mobile phone, this is something to do with metadata information of the photo taken. Some phones keep this information if you take photo with the 'camera' button on the left hand side. When it is corrected on the computer with a photo viewer, it doesn't update that metadata information. Solution is to open in a photo editor on the computer, save in correct orientation and then upload on the forum website. Try this, it might help.
Cheers
DFWSFO
