Doorplease
My 89 V6 Montero developed a nasty oil leak recently. Everything was fine until I changed the oil and switched from my usual Valvoline Next Gen, to Castrol (something or other.) I hopped on the highway and drove about 20 miles then stopped at a gas station and saw a pool of black under my car. I figured it wasnt me but to be sure i checked anyway. To my horror it looked as if a quart of oil exploded over my front suspension. I figured it was the oil pan gasket but upon further inspection it would appear to be a leaky head gasket on the drivers side at the front of the engine? (I apologize if that is a stupid description, I'm no trained mechanic I just find problems follow instructions and fix them). I was wondering if anyone had any luck with a Stopleak or even using an epoxy from the outside to repair/massively slow the leak or any other quick fix, as its not in my budget to pay for a tear down to change the gasket. Although i probably should due to the engine burning oil like its gasoline and my millage being a steady 14mpg. I am also considering an engine swap? any suggestions on crate engines at reasonable prices? Cheers!
