Checking compressions
Eaglefreek
Eagleless
If you can get your finger over the spark plug hole with the spark plug removed you can feel if there is compression. However, you can't measure it. A compression tester is fairly cheap and at least in the US, you can use teh tool loaner program at a major auto parts chain to "rent" one. However, you don't mention which vehicle you have and some engines have difficult access to the spark plugs.
gandrimp
You can listen for 1 or 2 cylinders that are weak on compression. On a weak cylinder (low compression) the engine will turn faster while turning the engine over with the starter.
iStan814
