Chevy Silverado Camp Rig
jimi breeze
jimi breeze
Hey folks, I thought I would finally post a few pics of my 2010 Silverado. I refer to it as a "camp rig" because it was built to get me there - off the beaten path, set up camp and enjoy the great outdoors. You can follow me this summer as a travel across the Great Lakes region, Canadian Rockies, to British Columbia. From there I'm sure which direction I'll take.
Kratos
Nice lookin truck you got there. Hard to tell from the pictures but that front bumper must kill your approach angel no?
jimi breeze
jimi breeze
Thanks for the comments. I haven't had any issues with my approach of departure angle, then again I haven't been sny extreme situations yet either.
The hood had been taped and painted to reduce glare.
Check out the list of mods on my website - www.overlandquest.com
vtarider
I'd love to hear and see:Wow1: a bit more about that utility camper shell you have on the Chevy!!!
Thanks
Dave
jimi breeze
jimi breeze
Did you guys check out my website yet? http://www.overlandquest.com/
I listed most of the mods there....
but here is a quick run down:
Bumpers – Ranch Hand Summit Bullnose Front and Sport back bumper. Chosen because of their lighter weight, durability, practical use- I wanted tough bumpers that I could stand on, mount accessories, and doze over road debris.
Winch - Smittybilt XRC 10,000 mounted on receiver cradle.
Side steps – 3” aluminum tubing, 3M non-skid tape, mounted on the stock mounting brackets. Good to have the lighter weight and full length reach the camper top.
Fender flares – Bushwacker extend-a-fender, I originally went with the OE flares then switched to these. They keep a lot more road debris off the truck.
Tail light guards – Garage Pro ¾” tube style guards which fasten via a pathetic weak method. A good base to tie them into a stronger mount
Roof rack – a low mount rack measuring only 4.5”. This is a carryover from my Avalanche but is now mounted on Thule roof mounts. The roof racks is a great place to store fire wood and wet gear.
Rear step – Bully swing away hitch step to ease access to the camper.
Blacked out hood paint- flat black enamel sprayed on to reduce glare from the silver hood.
Front fog lights – 6” Hella fog lamps wired into the existing fog lamp circuit (stock switch operates all forward ****** lamps).
Side lights – 4” tractor lights aimed at road side to aid in negotiating corners, finding camp sites, ect.
Rear lights – switch operated general lighting for camp use.
Tires/wheels – LT285/ 70 R17 Nitto Terra Grabber All Terrain tires mounted on stock GM rims.
A.R.E - Deluxe Commercial Unit, all aluminum construction, 6” over cab height
Roof rack – factory ladder rack with additional 1” cross bars
Kayak cradles – Yakima Landshark Saddles
Equipment mounting – Vehicle recovery tools
Dome vent – Fantastic roof vent.
Side window – passenger side full length tinted sliding window with screen.
Tool box – Drivers side door tool box, led lighting
Water source – 11 gallons stored in (2) 20 liter Scepter military water cans
Swing away mount – 5# propane tank, equipment box, and stove shelf
Shower nossel – Flojet 1.3 gpm on demand 12v pump, 15” hose with garden attachment for shower and clean up.
Front sliding window – reversed lock to inside.
Lighting – Amber rear 12v porch light.
daly
Thats a great looking rig, I've been contemplating getting a topper like that or roof rack to carry my canoe or kayaks.
chilliwak
Hey Jimmi if you are in B.C. this summer then please let me know. I can share a cold one with you and also let you know about cook kayak places, among other things. Cheers, Chilli...:)
jimi breeze
jimi breeze
The cap is an ARE deluxe commercial unit 6" over cab height. I ordered it with the half tool box on the drivers side and sliding window on the passengers side & front. I also ordered the ladder rack to mount my boat.
I added three more 1" crossbars that fit Thule products just fine. Inside I ran 12 volt from the auxiliary battery to a junction box. There I split to a fuse box and power port. I also use a 12 volt converter that I can run and extension cord to for shore power. I used LED lighting throughout (camper, toolbox and rear exterior door. I also added wire shelving for my clothes, ect. I built a floor cabinet for odd items that don't get used often. I use the top of it for storage also. This gives me enough room for the 3'x6' folding gym Matt that I sleep on (can fit two). I cut a hole in the top and mounted a Fantastic roof vent. It is wired for intake and exhaust.
If I were to do it again I would get a single door so I would have more mountable space on the exterior. But this really fits my needs to be stealthy, fit in wherever I go, low enough to mount the kayak, and provides a quick easy sleeping arrangement.
Any other questions pleas ask.
greatwhite24
