Christmas wth the LR3 Again
2010's and 2011 LR4's have some weird transmission issues as well
I have a customer that has a 2011 LR4. He towed a 5500 lbs trailer for a weekend of fun in Moab. Came home, and the next morning the the truck wouldn't move. Land rover can't figure it out and the transmission shop says they think the transmission is dead. His LR4 only has 65K miles. that's pretty sad considering my D2 has 172K and I've towed with it before. Its never had a transmission issue.
I told him to get a 1 ton if he decided to do anymore towing. Transmissions for LR4's aren't' exactly cheap
Haven't seen the dead trans issue yet. Most I plan to tow with my LR3 is my pop up camper. It only weighs in around 1700 lbs fully loaded.
In rust belt conditions, check the shifting fork on the transmission as well. This was an early issue with them. Might be worth a look at it.
Shift Components;
LR012704 - Lever
WYH000040 - Nut - flanged
VYH500020 - Nut - Hex
TYG000050 - Bolt
TZT500040 - Bush
TYF000050 - Washer - spring
Seems your LR Tech is intimately familiar with this issue now. Wondering if Liquid Tape is the solution?
Liquid Tape is a rubber coating for use as electrical tape and insulation. This flexible coating exhibits excellent protection from acid, alkaline, and abrasion, as wells as sealing out moisture and salt permanently. Liquid Tape has the strongest dielectric protection on the market; 1,200 v/mil, 5 – 7 mils per coat. Our rubber based coating will not harden, unravel or become brittle in extreme weather conditions like our competitors' vinyl based product. Available in 4 oz Brush-In-Cap Carded and 6 oz Aerosol.
good ole plasti-dip! These guys are a hidden gem! Thanks for the link.
So, I've got the LR3 back and for now I'm sticking with it. I'm going to apply some liquid tape to the problem wiring behind the wheel well and add some extra protection on top of it. This is my Achilles heel and if I can remedy it, all should be fine. The LR4 is nice but the LR3 is paid for and set up the way I like it.
Corrosion is a beast to deal with. Cancer so to speak in an electrical system. I deal with this a lot in Hawaii due to salt air and humidity. I am also a helicopter mechanic so corrosion prevention is a daily routine of every job we do.
The key is treating and preventing or vice/versa if you will. Many times we clean the exposed portion of a connector but that does not rid the cancer. The corrosion will eventually work its way back to the same problem areas with the same results..........failure. To properly treat a corroded connector, it needs to be disassembled which can be a project.
I recommend if you find a corrosion prone area, you de-pin the connector and thoroughly clean and treat the entire male and female connection. Once thoroughly cleaned and treated, re-pin the connector and test it to ensure all is good. Once your operations check is complete and everything is working well, you can now perform the prevention process. Disconnect, use a good thin coat of dielectric grease on the inside of the connector and then reconnect. You may also pack the backside where the wires go in with dielectric grease which helps dissipate/repel water as some added protection.
Now seeing the tip on liquid electric tape by Plasti-Dip, I will be trying that on the backside and over the connectors instead of the dielectric grease on the outside. We use this stuff in aviation called pressure tape but is super expensive so its not necessary in all areas and I surely do not plan to use it on my LR...lol
I will still use the same cleaning and prepping on the interior of the connector as I always use.........can't go wrong.
Keep in mind, some connectors are quite busy with so many wires! My take is, if I find a known corrosion problem, the extra time taken with the above steps will save me tons of money and time in the long run. Generally, a quick cleaning and dielectric anytime I disconnect a connector will suffice! For those times I do find heavy corrosion or a known fault related to corrosion the above steps by completely disassembling, cleaning, treating, and preventing if performed correctly will get you back on track with no further issues in that specific area. Its just typical prevention after that.
Now that I know the wheel wells in the rear are a problem, when I do my TR bumper this weekend and the trailer harness, I'm going to take the time under the rear wells to properly treat for corrosion in those areas. I just added a few more hours to the job I guess!
Hope this helps, corrosion and electrical don't mix and surely make things frustrating.
Thanks for all the advice. I'm going to pick up some Liquid Tape and have at it, will likely cover it all afterwards with flexible plastic sheathing and tape it too.
good luck and keep us posted. I am sure many of us can learn from your experiences in hopes it potentially allows us to prevent some of what you may be dealing with.
Cheers,
E
LukeSkywalker515
