Cleaning Synthetic rope...
jeepdreamer
I have a couple large-ish (about the size of your wrist) diameter synthetic recovery ropes. They get dirty and dusty while on the trail and wondered what the best way to clean and preserve them is? Soak them in a bucket of water and then air dry??
Anyone have a good solution??
Hose them off, wash them in a bucket with a little soap, rinse well, hang to dry out of the sun....
Thats how we wash rescue lifeline, too.
I thought Nylon was good with UV and it was Poly that was bad under UV??
Nope. Nothing is 100% UV stable (including steel, for various values of stable) but ideally you should minimize all UV exposure.
Some of the high performance synthetics (spectra, etc) are pretty much OK but as a rule it's best to minimize the exposure if able. If not, inspect and replace as needed.
I fully understand that nothing is 100% UV resistant for what we are talking about, but Timmer specifically mentioned Nylon double braid.now i am not sure what he is comparing this to? It takes a long time for UV to destroy a rope.
I wash my synthetic ropes/winch lines with Woolite on the delicate cycle, then let them air dry. Work awesome.
~ James
~ James
Have you tried the new lavendar-scented Woolite? It's pretty awesome -- the winch smells "Springy" fresh now.
compressed air
If its just light dust I use compressed air to blow them clean. I agree that ropes should be protected from the sun. Especially if they are on the winch all the time. Keep them covered.
That can actually blow dirt into the jacket of the rope. Vacuuming is probably better. Or just rinse off.
Also dont use machine washing detergent on fiber ropes. the crystals in the detergent cut the fiber.
use dish washing liquid instead I recommend Doc Bronners or Dawn. Woolite seems like it would be OK as well.
Fj89
