Schattenjager
What PSI do you use on your CO2 regulator for tires and air tools? I'm shopping for a new regulator and found this one - wondering if 150psi is enough.
Also, why do I need a true regulator when the tank has a pressure valve (on/off) built in? Something like this one is what I would really like:
I know some of the dual gauge setup are very pretty with liquid filled faces and rubber 'armor' on the instruments, but how is all that necessary for 4x4? Seems like simple is better in every regard. What say you?
