coil question?
OldSven
Just got your PM. If you are looking at doing a more inexpensive coil build I ran a set of 4wd TRD Tundra struts off of anywhere between an 01-04'. Go to www.extremetrucktoys.com for some bolt on spacers. The Tundra's will give you some lift and the spacers will finish it off and not screw up the ride like the "in-coil" style spacers will. Swap out the top plate and install your Tacoma one and you should be good to go. The other route you can go is to get a set of just Tundra coils and skip the spacers by getting some of those new Bilstein adjustable 5100's from like www.wheelersoffroad.com and that way you will have a coil that can carry the weight and the ability to move them up where you want them. Hope this helps let me know if you have any other questions.:D
zhukoveli
