Cody1771
Here a some common machinist terms explained
Machine - A mechanical device for the removal of redundant parts of the operator's anatomy. It is fitted with various lethal weapons, known as tools.
Machinist - A person suffering from the delusion that they control the above machine. Chiefly employed in exhibiting grossly inflated wage packets to non-engineering friends.
Tool Setter - An interesting animal kept by the management and trained to replace broken tools, etc. Is very docile when deprived of sleep.
Q.A. Inspector - A survivor of the Spanish Inquisition. His chief function is to weaken the machinist's nerve, thus rendering him easy prey to the machine. This is done by informing him that certain dimensions are oversize and, after adjustment, are then undersize by the same amount.
Estimator - An illiterate whose mental processes cannot assimilate the fact that there are only 60 minutes in an hour.
Tool-grinder - Someone who can grind a cutting edge on a tool and leave it in exactly the same state as before.
Reamer - A device for producing various patterns on a bore surface.
Tap - like a reamer but much more brittle
Test Gauge - An instrument made of metal which has the peculiar property of momentary expansion or contraction
Chargehand - Strict caution to be taken with this individual. From his frequent inquiries as to the number of hours you have worked, it must be assumed he is connected to the Income Tax authorities
Laborer - This specimen has no ambition, does nothing all day and stays on overtime to finish it. Always missing when wanted. Very obliging a week before Christmas.
Foreman - Very rarely seen except when you pick up a newspaper or fill in your football coupon
Wagepacket - delayed action bombshell
Bonus - Latin name for carrot
Scrap - See Swarf
Swarf - Chief product of engineering
Component - By-product of the manufacture of the above
Finish - An abstract term used by the Q.A. Inspector and something that is never good enough
Bolt - A cylindrical piece of metal with a helical screw on the outside that is either under or oversize
Nut - Something that never fits the above
Location diameter - A size that is never right and is always produced by another department
Faulty set-up - An accomplishment always achieved by the opposite shift
Model - A standard of excellence produced accidentally
Coolant pump - A device so designed as to deluge the machinist with oil or water when he is not looking
Scrap - See Swarf
