Conqueror owners- wiring update!!
Dendy Jarrett
Expedition Portal Admin
Staff member
Hey, Guys:
After waiting 9 months, ... Mega Manufacturers finally sent me a wiring schematic for the trailers.
We would have never figured this thing out! Two wires charging the battery and one of the two (wire to negative terminal) is the Earth wire for the lights! Huh?!?
The blinker wires require a jump on the truck side to work properly.
See the attached image.
Hope this helps ya'll!
Dendy
Also attached as a pdf here:
http://www.expeditionportal.com/forum/showthread.php?t=23703
wesel123
Holy cow I dont even have a Pink or Purple:Wow1:....What the heck??? I got mine working but still do not have a way to charge the battery other than shore power.
Dendy Jarrett
Staff member
Yeah, I think that the new models may have different color wires, but the basic set up is the same. This should help you with a meter determine what goes to what with the same format.
D
XJBANKER
SO my trailer has a 7 pin plug on it but I only have 2 blacks 2reds a white and a grey. it is only hooked to 4 pins. My only guess is to trace the wires down. Does anyone that had a compact look like this?
From the diagram above I marked where the wires are pluged into the plug vs the jeeps side. Any advice would be grand.
XJBANKER
believe it or not I actually got them to work tonight.
2 red wires had to go to the blue terminal for the running lights
White wire went to the red switch
grey went to the brown
2black I left on black but I dont know how to test if the battery is getting a charge from the car.
This is hooked up to my wifes grand cherokee becasue she already had the 7 pin plug on it. I think I am going to rewire my XJ for the 7 pin as well.
Houie
