naterry
13 Cheeseburgers
Gents,
Happy Turkey Day! :chef:
I'm burning some time with the stuffing in the slow cooker digging for information on interior panel and counter top material options. We used SS sheet over plywood inside the first Ute. This was a simple and quick solution but it quickly became dimpled and scratched. I was also concerned about using plywood near heat sources.
The boxes in the new Ute will be "minimalist" 8020 framed with the ability to add/modify it as needs change. I think I'm looking for three different materials:
Any input or advice would be greatly appreciated!
Cheers,
Nate
- Counter Tops: Lightweight, heat and scratch resistant, high stiffness. Leaning towards Corian®: (http://www.dupont.com/products-and-services/construction-materials/surface-design-materials/brands/corian-solid-surfaces.html)
- Lightweight Load Bearing Panels: These would be for bed and bench seat platforms. I want to minimize bulky support frame members by using the right material. Composite sandwiched honeycomb panels would be ideal but that stuff is pricey! Foam, balsa, or birch core laminated paneling is also an option, but also not cheap. There has to be an economical solution for this, just haven't found that unicorn material...
Examples:
http://www.dickblick.com/products/helix-ultra-lite-core-plain-edge-board/?clickTracking=true&wmcp=pla&wmcid=items&wmckw=22992-0008&gclid=CjwKEAiAtNujBRDMmoCN46aB8noSJAC7SYv7gQef8O399GUG_RewPVB_fx7Jubxb6lfM0XLVfjLEzRoCKt7w_wcB
http://www.acpsales.com/Fiberglass-2-Ply-Honeycomb.html
- Lightweight Non-Load Bearing Panels: These are the sides of boxes. Perhaps Formica'd 1/4" or 3/8" plywood, but really anything I can hit with scotch brite pads to take off scuffs, spills, etc.
Cheers,
Nate
