ReluctantTraveler
Hi y'all! I'm in the exploratory phase of building a DIY EarthRoamer/Tiger camper.
After a 3-week trip up-and-down the East Coast of the US in a travel trailer, my family and I want something that's easier to drive, easy to setup/teardown, and lets us explore random stuff along our drive without fear of getting stuck in a parking lot (I'm looking at you, Whole Foods!). We're not planning on doing any heavy offroading: mostly just campgrounds, boondocking, and moochdocking.
Build details so far...
Some specific goals based on what we learned from our travel trailer include...
I've attached the current working floor plan. Some specifics worth noting...
Some to-be-worked-out open questions I'm still pondering (suggestions welcome)...
- Built on a gasser F-550 or Ram 5500 platform with a 12' steel flatbed (before anyone brings it up, I'm not worried about torsional flex for our type of use)
- 8' x 12' floor/box, with a king-sized cabover sleeping area
- Marine-ply and rigid foam construction, with epoxy/paint exterior
- Needs sleeping for 4 plus a small dog
- Shower, toilet, heat/AC, stove and fridge required
- Enough water and solar to run off-grid for a day or three if needed.
- Four-season capability (we want to take it to the mountains for snowboarding in the winter).
- We want lots of counter space. Cooking for 4 people with a small counter sucks.
- A hallway that can accommodate 2 people side-by-side. Having to literally climb over someone to get from one end to the other is a pressure cooker on longer trips. We need more hall space than our travel trailer allows.
- Beds that don't need to be "made" every day. Folding down or out beds with sheets is ok, but having to remove/put on sheets won't work for us.
- A private place to get changed
- Lots of big windows to extend the feeling of being outside when the weather sucks
- A dinette than can seat all 4 of us comfortably
- STORAGE!
- The dinette will double as a couch, with a backrest along the rear wall
- A tri-fold twin-sized foam mattress will fold out from one of the dinette benches for the bottom bunk. A fold-up/drop-down murphy bunk will fold down from the wall for the top bunk.
- I plan to use a portable induction range for more counter space and the possibility of easy outdoor cooking.
- The open space is 4 feet wide, enough for my wife and I to stand side-by-side or walk past each other without the other needing to move out of the way.
- The shower and toilet are accessed through a hallway which doubles as a changing room. The door into it will swing 180 degrees. It can close off the toilet room entirely, or lock inline with the walls to create a changing space.
- Access to the cabover ladder is also through that door
- Should I use a roof-mount AC, or a simple window-AC built into the wall? Should I get a traditional RV AC, or a fancy dometic 12v?
- How much solar and battery power do I need?
- How much water is "enough"? What's the correct fresh water:gray water ratio? (We'll be using a cassette or composting toilet, I think.)
- Where do I put the water tanks, in particular, the gray tank relative to the shower and sink for proper draining?
- How do I setup the system for winter? Do I need heat pads on the tanks, or is keeping them in the living space with heat enough?
- Can I wire a gas/petrol heater (like a diesel heater, but with gas) into our tank with a removable flatbed camper? Should I?
- With enough battery and solar, should I consider electric heat instead to further reduce my gas consumption?
- I want cabinets with shelves and drawers, not just big empty caverns for storage. What's the cheapest way to do that, besides building my own? IKEA? How do you add locking latches?
- We would love a passthrough to the cab. Is that possible with a flatbed camper, or does it need to be an integrated build for that?
- Casette toilet or composting?
- Is there any concern of leaking with a window over the cabover bed (a stargazing window)?
- Could I fit a small RV dishwasher in there?
- What's the best way to attach racks for bikes and snowboards? Roof mounted? Hitch rack off the back? Integrated racks on the back of the shell?
- Similarly, what's the best way to store a full-sized spare? I won't have huge offroad tires, so I don't think I need an EarthRoamer style winch system.
- What should I call it? We love pirates in our family, so I'm planning to fly a jolly roger off the thing when at camp (I even toyed with a shiplap exterior for a more nautical look). I'd love some sort of icon or logo or name that's adventure & pirate inspired.
