CRAP!
I highly dislike rethreaded tires, and would never run them on my dodge. That being said I have had failures with originals and recapped tires. Lots of commercial trucks run them for the savings at time of purchase. You can spend sometimes double what a recap costs for virgin tires, 300 ish per recapped tire versus 600 per virgin rubber multiplied by 16 or just 8 if you only do the trailer. Thats why tons of large fleets do that. All the savings go out the door with the cost of repairs when a carcass takes out the rear corner of your trailer and damages frame crossmembers, and possibly your load. It could happen with either type of tire though.
I personally have had a higher ratio of capped tires go bad. Not always catastrophic, some times the carcass was cracking from being old or the tread separating so they were replaced. I try and get virgins but on occasion I have had to put caps on because of availability or $$. We all face that choice at one time or another I guess. Just check tire pressures and be safe out there Glad you did not get injured or damage your truck.
aaah the old delamination trick
You should try the tire blowing in half while passing a semi !:Wow1:
Twohandsonthewheelatalltimespreventslossofcontrolduringexplodingtyreincidents_zpsa00b1f01.jpg
On a scale of 1-10 this rates as a 50:Wow1:
Two-three weeks ago some jerk illegally dumped tires behind my house in my alley in my pathway to my back gate, thought nothing of it.
I had to move them outta my way to get in my house, two were bald 37" all terrains, one old km, and one of the last tire I am certain is that failed treadwright on a Nitto Terra Grappler carcass. .
Of course the city takes the trash outta the alley but not tires!
Wait, one Expo member has a tire problem. Gets new tires from the dealer, and the original tire shows up in another Expo member's back alley?
What the........
I got my tire changed at Big O in Tempe AZ in March of this year. The journey it took from there I could not begin to tell. But I will say that looks exactly like the tire I had changed! :Wow1:
Broadway and rural? makes sense, I am less then three miles away!
I am not sure if you got to see the tire off, but there is a big patch on the inside of the tire underneath where the tread fell off. Maybe it slipped passed inspection, but I am 100% sure that's why the tire failed.
Makes even more sense it was desert rat since all the tires were off-road related.
They probably pay someone to haul away the tires. The tire hauler maybe had a few that couldn't be resold, so he found a handy place to "dispose" of them.
When I pay that disposal fee on tires I always wonder what really happens to them. Dumped in an alley, or something else:Wow1:
It IS the very same tire. If you look in the middle of the scar, there is a pinprick hole that looks exactly the same in both pics. I think you guys could get a legal issue going with this here.
Jlbeats
