cummins owners that have boost guages
toastyjosh
I just installed a mech boost guage on my 99 and driving around town it never moved, for you guys that have guages when does your boost kick in.
RPM and speed?
Thanks
eggman918
'88 4bt he221w 6cm exhaust housing I see 4-5 at idle and 20 by 1400 under load and 26-28 from 1500 up at WOT EGT's never exceed 1,150* pre turbo this is in a 8K F-250 4x4 ZF-5 3.55 gears 33" tires
Buckshot62
My boost gauge moves any time i use the throttle. Gas it and it goes up... let off and it drops. Better go back and reread the instructions, I think something is not hooked up properly.By the way mine is a 99 24valve with 375,000 miles.
verdesardog
Any time you apply throttle under load the boost should start to increase.....Idle and coasting there will not be any boost.
toastyjosh
Ok so it works, in 2n and 3rd it gets about 2 to 5psi shifting at 2k, 4th goes up to about 10-12 at around 2kish. Does this sound right
IdaSHO
IDACAMPER
As previously mentioned, it has to do with RPM and load.
As in, same RPM going up-hill and downhill will net different readings.
toastyjosh
So i drove it to work today, hit 20 psi. I think that is pretty good. Turbo is loud at the psi. I have a BAHF intake so i am sure that is a lot of the noise.
Think runs good.
Palli
