Cummins powered Earthroamer on BAT
russ240
There was certainly more interest in it when it was on Ebay three years ago, LOL
zip
I prefer social distancing.
OH SNAP!!!!
mog
Kodiak Buckaroo
is the Owner around here? wonder what he is wanting for this thing
The fact that the owner is using a dealer to list this truck on BaT as a 'cut-out', would probably indicate that he/she is not going to chime in on the Expo Portal that has prior threads listing this as a 'salvage' title, nor give the reserve amount on a 'no reserve' auction. As always YMMV
A Toyota Celica gets the seats stolen and ends up with a salvage title, but all this work is 'normal wear and tear' on a truck with 52,000 miles?
work included replacement of its stock Powerstroke diesel V8 with a 5.9-liter Cummins inline-six
refinishing of the camper body
cab and forward bodywork were color-sanded
the insulated honeycomb coach shell was stripped and repaired before being refinished
received new EarthRoamer dometic windows
replacement vents, and a dual-pane motorized skylight
six new airbags
replacement compressor, solenoids, air lines, control unit, and keypad
New cabinetry,
a new diesel heater, split 12-volt heating and air conditioning system were installed under current ownership.
Both axles were cleaned, inspected, and fitted with new seals,
the rear axle received new bearings under current ownership.
mk216v
Der Chef der Fahrzeuge
six new airbags
New cabinetry,
I like the BaT seller's comment about how ol' ER #009 received "All 2020 updates." So that means it has a new LTi carbon cabin too? ;-P
PS--notice the clean Cali notes registration is expired, and license # doesn't match current? More stuff to weed through.
  • Like
Reactions: mog
zip
Hopefully all bidders have done their homework.
zip
The ad now has a link to their build sheet. This was written on that build sheet.
"The Earthroamer is CA smog exempt due to its weight and year"
mog
Kodiak Buckaroo
It was first registered in California on May 15, 2018, and a Cali registration is only good for 1 year. So the title will reflect that, but when it is renewed, you just get a new registration and plate stickers, not a new title, Red sticker on the license plates are good to 2021. Same for the license plate, if it is changed after the transfer/titling, no new title is issued, the license number is just reflected on the new registration.
Mcoleman
