Cackalak Han said:
I wouldn't put anything aluminum as a skid plate on my rig. Banging out steel > cracked aluminum. (not trying to be negative. Just posting my opinion
Opinions are OK but Google will help to get facts. Lots of different types of Aluminum are available for great skids.
5052 is one of the higher strength non-heat-treatable alloys. It has a high fatigue strength and is a good choice for structures subjected to excessive vibration. The alloy has excellent corrosion resistance, particularly in marine atmospheres. The formability of the grade is excellent and in the annealed condition it offers higher strengths than 1100 or 3003 grades.
Typical Applications
5052 is often used in high strength sheet metal work, marine components, appliances, fuel and oil tubing.
Comparison to 6061
5052 – An Aluminum / Manganese alloy, strain hardened and stabilized. It has moderate to high strength, and is non-heat treatable. Good welding characteristics and high resistance to corrosion in marine environments. A common sheet metal.
6061 – This Aluminum / Silicon / Magnesium alloy has been solution heat treated and artificially aged. Machines well with excellent welding qualities. Resists stress cracking. Good formability with medium strength and high corrosion resistance. Used in many heavy–duty structures, particularly for transportation and marine applications.
