Cyber Monday, 20% off + Free Ship!!! Vector OffRoad
Vector OffRoad
Supporting Sponsor
Cyber Monday! 20% off plus free shipping (CONUS) through 11/27 for the MP Table and the JK E-Dock.
MP Table (Multi-Purpose Table) Reg. $159.99 Sale $127.99 In stock and shipping immediately.
The Vector Off-Road MP Table (Multi-Purpose Table) installs to any vertical surface with a minimum surface area of “29-1/4” x 11-1/16”. When stored in the closed position the table only protrudes a maximum of 1.25” from the mounting surface. The working area of the table is 11" Deep x 27.5" wide.
Designed to provide maximum usability in a light weight and slim package, the MP Table incorporates ¼” holes and slots to allow the use of QuickFist™ Clamps and Molle Straps for mounting trail gear, tools and pouches to the table. There are also convenient holes along the outer rim of the table for hanging your cooking tools if you are using the MP Table as the base of your kitchen. To quickly deploy the table, remove the two knobs on either side of the table, fold the table down, and place the knobs back on the studs.
The MP Table is laser cut and manufactured in the USA from aerospace alloy aluminum. All of the mounting hardware is high quality stainless steel and is easily field serviced. Even the cables are 100% stainless steel and polymer top coated to further prevent rust and fraying. The MP Table will provide you with many years of trouble free service.
http://www.expeditionportal.com/forum/attachment.php?attachmentid=48902&thumb=1&d=1289230521
http://www.expeditionportal.com/forum/attachment.php?attachmentid=48904&thumb=1&d=1289230558
JKE-Dock (JK Wrangler Electronics Dock) Reg. $129.99 Sale $103.99 In stock and shipping immediately
The Vector Off-Road JKE-Dock installs directly to your 2007-2010 JK Wrangler dash using existing mounting points. It is 100% bolt on, and requires no permanent modification to your Wrangler. JKE-Dock provides a clean solid mounting point for your Cell Phone, GPS, Spot Messenger, Flashlight, CB, CB Microphone, Radar Detector, Ham Radio, etc… The Dock also has an integrated dash top storage tray. The tray is a great place for sunglasses or other small items you would like to keep close at hand.
JKE-Dock works in conjunction with RAM™ Mount accessory brackets and mounting balls. (http://www.ram-mount.com). Start with a 1" diameter RAM™ base with u-bolt(RAM-B-231U) and place it anywhere along the Dock with your favorite RAM™ Mount and Arm.
The JKE-Dock is manufactured in the USA using hi-strength steel tubing and stainless hardware. It comes standard in a durable semi-gloss black powder coat finish.
http://expeditionportal.com/forum/showthread.php?t=51732
Wolfbox
