Desertdude -1997 80 series build up
ShottsCruisers said:
So, you'll try a stock front D-shaft with the new arms?
Yes OEM shaft - (you might want to start finding one)
the DS balance work should be ready tomorrow - I will post my findings
Thanks Dude! Your efforts at the 4" mark will help many others! :bowdown:
I don't think I'm going to snag a front D/S. I don't want to drop the LX back down to the 4" mark. I know at my height I'll need to incorporate a D/C.
I'm anxious on your outcome. Both of us had vibe-ing trucks. If yours works out via hardware swaps I'm confident mine can too. I've had everything inspected short of the D/C shaft. My move will be to front arms and 6" springs. Slee has a very high success rate on the 6" kit. I'll bet by moving that axle forward, added more C/C, changing angles to everyone elses with the kit will result in success too. I highly doubt I have a problem truck.
Now I see what you're talking about shots:D :D didn't i say something about going 6" and being done with it like....hmmmm....about 2 months ago...sweet!!! you'll love it:gunt:
Ya...but..but...who listens to you? :hehe:
See, this way...if I experiment by doing all the crud I've been doing, then slap on the 6" and it works, I can take the credit and not you. :jump:
IF the 6" doesn't work....yer gonna pay! :xxrotflma
That's cool, however, I am not sure about the non-cadillac ride for your old 100 series loving bones:elkgrin: Actually with all the OME lifts I think going to bilstein 7100 would be a big improvement, that's what I would like to do at some point but I still think you will be wildly happy. Part of the reason I used before and to justify the slee 6" to myself was that it seems to be a kit that has very few problems ie no futzing around. and at that time there wasn't a 4" slee kit. But now you will most definitly have me on app and dep angles:victory:
I am happy to report that the Slee control arms along with the Stock front shaft have cured all of the initial drive-line vibrations I was having with the castor plates/DC shaft - In testing I had to separate out normal drive-line noise and BFG mtr tire sounds/vibrations - after cruising the highways at 80+ and many back roads and trails through Sedona this weekend I and happy with the out come
Points to note : my expectations for this heavily modified 80 series are not that it maintains its cushy SUV feel - rather it is trail ready ( moderate to heavy trails) - can carry the gear/weight of an expedition ( if needed) and I can drive it to the trails ( sometimes 1000's of miles away) safely and with comfort - I have accomplished this and really like the look and how it responds on and off the road.
(1) Did the Slee control arms and stock shaft cure the vibrations I had once I lifted the 80 and installed the Slee castor plates and DC front shaft - definitely YES
(2) is the drive-line completely smooth with no sounds - a subjective NO
(3) Could any of these sounds be tracked down as something wrong due to the lift or any drive-line issues - I doubt it (no)
(4) Would I recommend the Slee control arms and stock front shaft as a cure to vibration issues linked to caster plates and the DC front shaft - YES
Desertdude said:
I am happy to report that the Slee control arms along with the Stock front shaft have cured all of the initial drive-line vibrations I was having with the castor plates/DC shaft - In testing I had to separate out normal drive-line noise and BFG mtr tire sounds/vibrations - after cruising the highways at 80+ and many back roads and trails through Sedona this weekend I and happy with the outcome -
Points to note : my expectations for this heavly modified 80 series are not that it maintains its cushy SUV feel - rather it is trail ready ( moderate to heavy) - can carry the wieght of an expedtion ( if needed) and I can drive it to the trails ( sometimes 1000's of miles away) safely and with comfort - I have accomplished this and really like the look and how it responds on and off the road.
(4) Would I reccomend the Slee control arms and stock front shaft as a cure to vibration issues linked to caster plates and the DC front shaft - YES
OK, I'll get the arms and stock D-shaft and try them. I guess I'll remove my spacers and drop it down to the 4" mark.
At least you can see where you are - before you change too much - in trouble shooting it is best to do things one at a time and track down info -
Yes, we will do it in steps. I just ordered the arms.
I'll...take off caster plates.
Slap on arms and drive.
If bad with arms I'll remove the D/C shaft and front spacers which puts me at about your height.
Step by step this time. Do you know anybody who can loan me a stock front shaft if I need it?
DUDE: How much fiddling of the rear control arm adjusts was required? Do you know the arm length you finished at (from hole center to center)?
15 3/4 " C to C - this made the diff flange parallel to the transfer case in the rear - smooth as silk ;)
I also made sure the pan hard rods where dialed in within 1/8"
Note: My 80 is loaded so your milage may vary...
Gracias! We'll slap those arms on. Adjust everything and ride. I really hope I can stay at the 5.5". If not...oh well. Where can't a 4-incher go? :o
Wolfbox
