I'm looking at a older 1/2 ton quigley ford which has a 351 4speed.
I was wondering if when quigley did their conversion, did the gear they installed have the same rating as the original Van? Or did quigley turn all the vans into 1 ton?
Legally, the GVWR would be unchanged. With the current vans, the only change to the rear axle is wheel adapter to match the bolt pattern of the F-series front axle.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
