Mods if you want to move this to the snorkle wars thread please do.
Materials
Hole Saw
Drill
Pop Rivets
Rubber Edgeing
Length of pipe aslong as you need for your aplication
Pipe thickness 3" min size for most cars but 4 or 5" will work well also
Stainless pipe or normal if your not into the bling thing
90 degree rubber bend
2 45 degree rubber bends
Hose clamps to suit pipe thickness
rubber edging for the hole in the guard
the beaty of this system is that you can fit it for any vehicle no matter how long or short you need it to be, asfor the ram most of us just face it backwards with a 45 degree bend but you can pick up truck ram heads to suit 4" and 5" pipe.
I used 4" pipe and will be fitting a safari style ram head, these are available at all truck parts stores in Aus not sure with the USA but that is also where i obtained the rubber bends
Each end will need a hose clamp to makesure the snorkle is water tight.
im sure you can workout how to install here are some pics from my diesel GQ
Side on shot same style but diff car as i dont have a pic atm
Materials
Hole Saw
Drill
Pop Rivets
Rubber Edgeing
