stomperxj
Hi Guys-
I have always been a fan of 4x4 vans and have started thinking about them a lot lately. I really like the Dodge B-Series and don't see very many of the original Pathfinder versions or home brew 4x4 swaps on here. I'd like to post up some ideas for a build and would like some feedback on it...
Here are some examples:
Ice Box's B van:
A stock SWB window van:
Another yellow SWB:
Here are the specs I've come up with after some internet and junkyard research:
1975ish SWB Dodge B series van. 109.6" wheel base, approx 3300lbs curb weight stock
Find a mid-late 90's donor van w/ a fuel Injected 5.9 Magnum, 230hp and 330lbs of torque. swap all electrics, dash... etc for updated interior/electronics
Dana 44 & 9" ford from a 76-77 F150. Width seems to be close to stock width on a B Van at around 66-67" WMS. Geared accordingly
Dodge 46RE 4 speed auto tranny
Dodge NP231HD xfer case
32x11.50 or 33x10.50 tires
Fabrication would include all the front suspension radius arm mounts/shock mounts, xfer case cross member and bumpers/racks etc...
What kind of mileage could you expect from this setup? Somewhere in the 15-20mpg range? With gear the van would probably weigh around 4200lbs which is not a huge amount more than my XJ loaded with its 4.0L with way less power and torque at 190/220 stock. I would think high teens for mpg would be easily attainable while having a bunch more power for hills and towing capacity.
Looking at the project as a whole doesn't look that bad to me as far as time and fabrication. The front Radius arm setup doesn't have a ton of geometry to figure out. The main time consumer would be swapping all the wiring and dashboard over to the early van...
Any suggestions? Feedback? Am I nuts?![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Jess
Ice Box's B van:
![P6060228.jpg](http://img.photobucket.com/albums/v236/stomperxj/Vans/P6060228.jpg)
![popsvan.jpg](http://img.photobucket.com/albums/v236/stomperxj/Vans/popsvan.jpg)
Another yellow SWB:
![summercrush.jpg](http://img.photobucket.com/albums/v236/stomperxj/Vans/summercrush.jpg)
Jess
