crinklystarfish
I have a question for people that use any kind of diesel-burning furnace for blown-air or hydronic heating.
I personally have a Webasto Airtop 2000 S blown-air diesel heater.
Assuming a cold cabin to start with; when I set my (standard dial) room temperature controller to its mid point the heater initially fires up and burns quite fiercely. As room temperature rises the heater gradually reduces output (what I believe is the ‘constant modulation' function referred to by manufacturer) until it eventually stops calling for fuel and cycles down.
However, unless I turn the room temperature dial to ‘off', the heater fan never stops running and pretty soon starts to blow cold air which actively - and irritatingly - reduces room temperature. Unless I raise the setting on the dial, the heater will not re-ignite until temperature has dropped considerably - way lower than is comfortable. I assume this operating cycle is designed to reduce the number of times the glow-pin is required.
Is this experience shared by other people with diesel-powered blown-air heaters and are hydronic systems the same? ie do they seem to be designed to have overly-long periods between cycling down and re-firing?
