ExplorerTom
Awhile ago I emailed the “contact us” on the Cooper Tire website and asked the following
This is the reply I got from the Consumer Relations Department:
Not happy with that boilerplate reply, I replied with this:
Here’s her response to that:
So, there you have it. According to Cooper: they do not recommend airing down tires below your door sticker.
I have a 2000 Ford Expedition that weighs approximately 5000-5500 lbs (maybe more once loaded up). I use it for camping and offroading. I have a set of Cooper Discoverer ATP tires in 275/70/18 Load Range E. What pressure should I be running on the street? Also, it’s common to air down while offroad for better traction and ride comfort. Do you recommend this? And approximately what should I be airing down to for rocky terrain? Thank you Tom
Thank you for your email. Always follow the air pressure recommendation of the vehicle manufacturer as listed on the placard in the door of your vehicle. Proper air pressure is based on the weight of your vehicle and is determined by the vehicle manufacturer, not the brand or type of tire you have. Also, never exceed the max air pressure as listed on the sidewall of the tire. I have included a load and inflation chart for your tire size.
If you have questions regarding this or need more information please contact your vehicle manufacturer. There are several sites you can refer to as well regarding tire pressure safety.
www.ustires.org
www.nhtsa.gov
www.safercar.gov
Pamela
Consumer Relations
800-854-6288 M-F EST.
Pamela,
Thank you for your response.
I was hoping to get my question in front of someone more technical than the consumer relations department. I understand that the placard on my vehicle was developed by the manufacturer for on road use. However, I use my vehicle in other conditions than smooth, paved roads. Running street pressures in rocky conditions is bad for traction and bad for the tire.
Can you pass this inquiry off to the engineering department?
Thank you
—Tom
Sorry Tom, but an engineer cannot answer your question. We do not recommend running pressures below the door placard recommendation.
Pamela
Consumer Relations
