on 2005 FG649 single cab I recently .....
cleaned condenser
cleaned blower fan
replaced blower motor (second hand from Mitsubishi Lancer with minimal modification to screw holes)
regassed and one part replaced
tightened compressor belt
cleaned gauze filter which was a bit clogged up
ran water through the evaporator to clean out the dust that got past the filter and turned to mud
aligned duct with dashboard outlet on passenger (left) side
removed outside front panel that covers inlet and will make front facing 150x100mm grill (original 15x100mm is inadequate)
it works at least 100% better than it used to .............. I don't know 100% of what.
a long time ago condenser was moved from under wheel arch to under center, I don't know the effect on air flow.
I'll probably add a small computer fan in the passenger air duct just before the outlet.
I occasionally look for an external shade for the windscreen.
One day I'll insulate (heat and sound).
At the end of all that the system is inadequate for something with such a large angled windscreen. It works better travelling west.
