Spencer for Hire
Thanks. Looks like a long trip from Massachusetts but maybe worth it.McDonald Creek Provincial Park
Hopefully the weather holds for your camping. Enjoy!Forgot to mention this earlier. Last camping trip I learned that stainless steel garden hoses are not nearly as durable as rubber ones. An RV drove over my hose (I had it across the road, my fault) and flattened it in two spots. I've previously had vehicles drive over my rubber hoses without issue, and really didn't think it would be an issue with the stainless hose, but it most definitely is. It still lets water through, but is obviously affected in a big way.
The stainless hoses are awesome because they don't kink, are thinner and lighter than their rubber counterparts, but getting flattened/destroyed by other campers is a non starter.
So I've replace it with this rubber one. This hose is considerably bulkier & heavier. Barely fit it on my spool and in the drawer. I'll definitely have to remake that spool down the line. The hose also kinks like crazy, despite the "kink less" claim. But it also feels like a heavy duty beast, so at least that eliminates the issue of being crushed.
In any case, another trip coming up at the end of this week. Heading to a remote, backcountry site for about a week, and then (possibly) more front-country camping in a new park. Weather is looking iffy, so we might come home earlier than planned.
I was curious how much water my fresh water tank actually fit, so I picked up a garden hose water meter and filled up the fresh water tank. Water started pouring back out the intake at 33.1 gallons. The tank is advertised as 31 gallons.
Perhaps the meter isn't super accurate, or the water tank size is advertised under-size? In any case, glad to be getting the full capacity, with seemingly no air-locks preventing fill up.
In this experiment my water heater and water lines were already full of water prior to fill up.
The studs are all aluminium. You can see a stud in one of the photos I shared of my installation of the furnace access panel. Walls are azdel, yes.Your craftsmanship on some of these projects is top notch! I’m writing some of these ideas down for my little trailer to dos.
Was curious about Minnie wall construction, is it azdel and aluminum or is there wood studs and wood interior on these? How has this been in the winter months? Have you had issues with freezing pipes?
I use a 12v EcoWorthy pump, it works well, and even comes in handy around the house quite a bit. When choosing a pump, pay attention to how high (vertically) and how far (horizontally) it can draw water; the higher & further, the better. Make sure the pump is self priming, so there are no problems running it dry. Also consider the pump's current draw (amps) and how you will connect it to a power source. Most 12v cigarette lighter plugs have a 10-15a limit. I also suggest using a plug with a built-in on/off switch, as that's very useful and simplifies the overall setup.Looks like a beautiful trip! I was curious about this bit:
"That's a 150ft, orange garden hose pulling water from the river to the trailer."
Any issues filtering sediment out of the river or is it safe to assume you used a filter? We're also looking at some transfer pumps. Which pump worked best for you while camping?Love seeing what you've done to the unit.
Also noticed the Thrive series. They look pretty good.
Ahhhh, even better idea. I was thinking about the Milwaukee 20v transfer pumps or something along those lines but this is much more reasonably priced and I can use the 12v plug on the Ecoflow too.I use a 12v EcoWorthy pump, it works well, and even comes in handy around the house quite a bit. When choosing a pump, pay attention to how high (vertically) and how far (horizontally) it can draw water; the higher & further, the better. Make sure the pump is self priming, so there are no problems running it dry. Also consider the pump's current draw (amps) and how you will connect it to a power source. Most 12v cigarette lighter plugs have a 10-15a limit. I also suggest using a plug with a built-in on/off switch, as that's very useful and simplifies the overall setup.
Winnebago released a new line of trailers, Thrive. Some nice, modern changes here.
I found myself browsing the bunk-bed model 22MBH (https://www.winnebago.com/models/thrive/22mbh) and noticed that they implemented about half of the modifications I've made.
- Blinds: identical to what I installed.
- Spare tire: relocated to the exact spot I used, using the same exact mechanism.
- Lights: replaced the offensively white ones with soft-yellow, as I did.
- Added pantry storage.
- Added drawers under the bed.
Am I wrong in feeling I should be getting some kind of royalty kick backs?
All in the all, the new Thrive looks to be a huge improvement. They've fixed a LOT of the gripes/limitations I have with my current trailer, and even included a water tank that's double the size of mine. Wish it were bigger still, but even so, that's a big step up.
Now if only they used dual pane windows...
