derjack
Hi folks,
I have (or my mechanic) an issue with the engine removal of my E350 Econoline 7.3 IDI Quigley.
http://www.derjackistweg.de/engine-swap/
The engine should go out to the front. As you can see everything has already been removed. Though it´s not possible to lift the engine high enough, due to the oi sump to lift it above the front engine mount.
Problem is: At this stage, my mechanic is moving from "an easy swap" to a big amount of labor costs, is he needs to totally remove everything ...
Looks like no chance to to remove with the oil sump in place. To remove the oil sump (+ oil pump etc) itself you also need to lift the engine at least 15cm or 6 inch. And from that point on it gets dirty and tricky. For installation I would need to install the engine with an open bottom end- not a good idea.
Has anyone a better idea, made out of any experience? My guys tried with a fork lift and failed. The fork lift lifted itself, when tried to lift the engine :Wow1: Though that´s not the main issue at the moment.
Any advice to get the 7.3 out?
