electric roof bed
If you want to have a working range of over a metre, then linear actuators are probably not what you are looking for.
If you do not have a pop-top, then something like the Happijac bed lift could be a possible solution.
These units are not cheap, but they are pretty well built and will last for many years. I have personal experience with these bed lifts, as I used to sell them.
do you have a link or do you know where to buy it or how to make it HUM, I want to put two twin beds on top of the living room, taking advantage of space in such a small space is vital.
Thank you
Cheers
How funny! I went searching on this topic because I'm planning to do the EXACT same thing for my kids' sleeping arrangements.
I'm currently weighing the pros and cons of electric versus mechanical systems. Some options I'm considering...
  1. An electric lift with actuators in all four corners.
  2. Gas-struts, where I literally just push the beds up or pull them down. I'd use pins to lock them when up.
  3. Rope-and-pulley system, with a sailboat style winch to pull them to the ceiling.
I had also considered a murphy bed style system, where the bed tilts to the wall instead of raising fully up, but this would result in comically tiny dining area windows, so I don't think I'll be doing that.
I'm partial to the mechanical options simply because it's less stuff to break or fail on the road.
If you're considering the actuator system, I found this YouTube video on how someone built one for their van that you might find useful:
One other thing I've considered doing is having the dinette benches be 6' long, with twin mattresses underneath the cushions.
That lets the bed stay made (with sheets and a comforter/blanket), without taking up usable space during the day.
I'm curious to hear what you decided to do, @Ferjablito.
hello Reluctant
Well, I haven't gotten around to it yet since we've been waiting for delivery for about 6 months but we continue with the initial idea of an electric bed assembled by ourselves in case there are problems in the future, we can repair the system, possibly electric actuators.
hello Reluctant
Good luck whatever you decide! I do hope you'll come back and update this post. I'd love to see what you build!
Short answer... yes and yes.
The actuators I am using are a Chinese clone of the Linak LA36 actuator, each having a load capacity of 3400N and dual Hall sensor feedback. Much cheaper and virtually identical to the Linak actuators.
I have inspected them internally and am impressed with their quality. Not the quietest, but that is probably to be expected, as they are industrial actuators with all metal gears.
The controllers I am using were designed specifically for Linak and are normally only available through them. The controller has the ability to synchronize 4 x 20A actuators in both directions and has inbuilt safety features.
This is mandatory for my roof lift actuators, as I have a hard sided pop-top, but I have a second identical controller that I will use for the bed lift.
The reason for using the second controller on the bed lift is the built in safety features, like stopping all actuators if one should fail and over current protection, but it's not really necessary.
The controllers also add the ability to utilize a momentary switch to start and stop actuator travel, which is ideal for lazy people like me that don't want to hold the switch down while the actuators are in motion. :)
Linak now make their "IC" range of actuators, which have the inbuilt ability to synchronize, but from what I have seen/heard, the external controller is more reliable and more predictable in its functionality.
As I said... you don't need a controller for a bed lift, nor do you really have to worry about keeping the actuators synchronized.
An actuator based bed lift system can also allow you to level the bed, if parked on uneven ground.
The bed lift in the Blismobil expedition campers definitely have that functionality.
good night SkiFreak
With 1200 of career I could manage the linak 36 in its longest version it has 1200 of career but it costs an arm and a leg, can you link me where you bought your Chinese clone.
Thank you.
Greetings.
Fernando.
No, I do not have any experience with that brand, nor have I used linear slides, but they could have some advantages over linear actuators.
Just note that plastic gears are quieter, but metal gears are stronger and last longer.
The company I bought my actuators from is Wuxi Hongba. If you Google their name you will find their website.
From memory, the model of actuators I am using have a maximum stroke length of 1000mm, but bear in mind that unlike the linear slides you linked to above, the fully extended length of that actuator would be around 2200mm.
Where the name brand actuators normally excel is in outside installations, where the actuator has to deal with various weather conditions.
If using the actuators inside, that is pretty much a moot point, and it is where I believe the Chinese clones are a better financial option.
Wolfbox
