Electrical help needed
HazMan
Ok brains trust, I need some help.
This morning (at 4.15am) when I went to start the truck I turned on the ignition and none of the dash lights came on straight away.
I tried starting it and it cranked over very slowly, not enough to start. I cranked it over a few times and luckily it started and I could drive to work.
Normally I would assume this means flat battery but when I turned the ignition on and off a few times once I parked, I could hear a relay clicking and occasionally I would get all dash lights on like everything is ok.
Is there a general power relay connected to the ignition switch? Could this be faulty?
Or is it just flat batteries?
Sean
HazMan
I have never had any other starting problems and did not leave anything electrical on or a door ajar to drain batteries overnight.
I am away from the truck until tonight and hope someone might be able advise.
Sean
pugslyyy
Occam's Razor says bad battery or dirty contacts somewhere. Don't forget to check the grounds.
HazMan
I am on my way back to the truck soon and fingers crossed I'll find a loose earth or dirty terminal.
kerry
No sure what your truck has but my truck had two 12 volt batteries in parallel and I had nothing but trouble with it. One battery was always a little weaker than the other and drawing the good battery down, then causing overcharging. I finally installed a marine battery switch allowing use of either, both or none. Problems solved.
gait
connecting + and - to opposite corners of parallel pair, so that total cable length to each is the same, can help reduce imbalance
Tdavis8695
