Electrical Wire Identification - What the heck are these plugs?
SONICMASD
Hi Guys,
When I removed my knee guard trim below the dash I noticed a few wires that are not plugged in.
#1. 4 pin square connector, that plugs in to a large metal box just above the left front speaker, just to the left and in front of the power window relay board. This same box has 2 other wire harnesses already plugged into it.
#2. 2 prong connector, way in the back, right next to the power window relay, just above the hood release cable
#3. Green tipped connector from a cord that has a fabric coating on the outside, unlike the normal rubber/insulated coatings.
#4. Female plug with a yellow sticker that says "INSTALL FUSE HERE".
I have been unable to ID these in the FSM so fingers crossed someone here knows what they are.
Sabre
Overlanding Nurse
No idea, but every vehicle has stuff like that. One wiring harness for several trim levels and such.
jlocster
Like Toasty said most likely alarm wiring. This may help ---> link
The metal box behind the speaker is the alarm module
If your Gen 2 is wired like the Gen 2.5s the 4 prong plug connector is the motion sensor.
taunger
