Espar Airtronic D$ Air Heater Install Advice
Hey everyone!
I would like to install a recently purchased Espar Airtronic D4 Air Heater.
I need to tap into the diesel fuel tank.
Has anyone done this before? Any suggestions where to tap into the existing fuel line?
Thanks in Advance!
gait
on a Toyota Coaster I teed into the line from tank to engine, near the tank. Avoided the return line.
With my Canter that approach failed as the line drained overnight. I could never find a leak. I drilled the tank and installed a webasto (similar to ebersp....) stand pipe. Similar to this https://www.ebay.com.au/itm/Fuel-ta...487943&hash=item41aa1a1baf:g:DZIAAOSw2GlXKbNu Used a step drill which works well with thin metal. Usual precautions drilling with grease on drill, drain tank after drilling, magnet in bottom of tank for a while. A long time ago (in a land far away) it used to be that drain plugs in sumps and tanks were magnetic.
I cut too much off the end of the stand pipe and have to remember to leave enough fuel in the tank if I need the heater. I have two tanks. I couldn't be bothered with a third tank for the heater, and there's long periods when its not used.
oskarf150
