ExPo 100 Series Registry
1. Year, model, color: 2021 Heritage Edition (US), Blizzard Pearl
2. Name of owner/screen name: Name: Mac Screen name: drbeemer73
3. How long have you owned your 100 series? Is this your first?: This is my first 100 series. Also have an FJ60 (see pic below), the FJ40 & FJ55 are gone.
4. Mileage at date of purchase and present mileage: Purchased with 12,000 miles Oct 7, 2020.
As of June 1, 2025 it has ~40,000 miles.
5. Your favorite mods:
As of June 2025:
NO lift, F/R bumpers, winch, or dual batteries, so "Offroad Lite".
When the stock battery needs to be replaced I will go to a much larger battery using Slee's larger battery box.
New Tires: Apr 2025, 48,000+\- miles, added Michelin Defender LTX 285/16 M/S2 (love Michelins). I use 39 psi.
Clear wrapped
Ceramic coated
Ice blasted the underside, then under coated (+ not driven in winter)
Sliders, Slee
Skids
Air compressor, ARB dual, mounted underhood with Slee mount
Lockers, F/R, ARB. Stock gear ratio is 3.31 (now 3.90 with F/R ARB lockers mounted in off the shelf Toyota diffs, which is the only way to get the front ARB locker).
Auxiliary 12.5 gallon gas tank by LRA (stock tank is 24.6 gals for a total of 36.7 gals)
ARB rear drawers
Air compressor outlet near/under rear bumper for easy air hose access to rear air bags when hauling our Airstream Basecamp, plus its tires
Trlr brake electric hook up
Ham radio, in cabin: unit is in R/R wheel well cubby. Roof mounted fold down antenna. GMRS frequencies have been added using the “MARS Mod”.
Apple Car Play (Sirius XM is stock)
Diff breathers by ARB
Locking/keyed lug nuts
Rear tail gate light from Brendan Bonser in AU, Dec 4, 2024 on FB
Garmin Tread (comes pre-loaded with all kinds of apps, trails, etc., such as iOverlander
Air bags, auxiliary, in rear, to compensate for the added weight of the above and for the tongue weight of the Airstream Basecamp 20X an on/offroad model
Loaded with survival/camping gear: Flashlights, GMRS handheld radios (Rocky Talkie) , fire starter items, hatchet, handsaws, Gerber shovel (has an integrated pick), First Aid kit, jumper cables, recovery gear, jumper cables, IndeFlate to deflate tires, tire gauges (hi/low pressure), serpentine belt, and much more.
6. How your 100 is used: Adventure, plus it tows an Airstream Basecamp 20X (an on/offroad model)
7. Your 3 favorite photos (keep them updated): See below.
1. Year, model, color, etc: [2000, LX470, White]
2. Name of owner/screen name: [catalyzer]
3. How long have you owned your 100 series? [5 days] Is this your first? [Yes, newb]
4. Mileage at date of purchase and present mileage: [280K, putting 3k miles taking the scenic route from TX back to CA via NM, AZ, CO, UT, NV]
5. Your favorite mods... If any: [previous owner installed OME 2" lift, which works well on trails so far]
6. How your 100 is used... ie. DD, family adventure, overland travel, etc.: [purchase for full-time adventure/overlanding/business development across the USA, JP and then Indonesia]
7. Your 3 favorite photos (keep them updated): [attached]
2eleven
