while this could be one of those things thats more trouble than its worth, or may not work at all. i was thinking today, on the 2wd F series Super Dutys, is the spindle the same size as the E Series Vans?
I have not looked at the rotor yet, but would imagine it is a hub/rotor combo on the 2wd Vans. if the spindle and bearings were the same, could the F series hub/rotor be installed to get the F series lug pattern without having to run wheel spacers?
Id imagine if the bearings were the same part # then that verifies that it should technically fit, caliper clearance would be the only thing left to address if not a direct swap?
If this has been discussed, and you know of the link, please post it up.
