Was climbing up to the Eisenhower Tunnel on I-70 West side in 4th gear when near the top the temperature gauge starting rising a bit and shortly after I heard a high pitched whine. Surprised me at first and it went away quickly after heading downhill in the tunnel so it only lasted a minute or two. I now suspect it was the fan clutch engaging due to the increased temperature. Does anyone else hear the fan clutch engage like that? I tried to wiggle the clutch and water pump shaft when I got home and everything seems tight. The fan itself did seem a little tight. I was expecting it to freewheel easier than it did. It's very rare for my temp gauge to climb at all so I don't think I have much experience with the fan clutch engaging. The temp gauge did rise once in the past on the same climb but I didn't hear a whine when it happened. Normally I'd expect a kind of roar and not a whine when the fan clutch engages.
Or, does someone think the whine could have been something else?
