Fender flares
I think they are the same in the rear but the front might be different. If I were you though, I would use plasti-dip matte black on your LR4 flares and it will look awesome. Provides a bit of protection from weather fade and light scratching as well on the trails but not the heavy stuff obviously.
Also, you can plasti-dip with the parts on the car which will save you a ton of time and effort.
You can pick it up (Plasti-dip, or spray on vinyl) at just about every hardware store now and its relatively cheap. About $8-10 a can out here in Hawaii. Then you can do the hood black out as well :wings:
Will the LR3 fender flares fit on an LR4 (2011)? Prefer the non-painted look
I think the LR3 parts would fit just fine on the LR4. Especially considering the painted fenders that came on the 2009 LR3 are the same part #s as the LR4 fenders.
The parts you will need are:
DGP000145PCL
DGP000155PCL
DFK000045PCL
DFK000055PCL
DFJ000022PCL
DFJ000032PCL
Sweet!
DGP000145PCL
DGP000155PCL
DFK000045PCL
DFK000055PCL
DFJ000022PCL
DFJ000032PCL
I had mine swapped when I purchased my 2014 HSE. Here are the part numbers I used, which were mentioned above, plus the ones ending in 124 and 134.
DFJ000022PCL
DFJ000032PCL
DFK000045PCL
DFK000055PCL
DGP000145PCL
DGP000155PCL
DGP000124PCL
DGP000134PCL
Photo shows what it looks like now.
You are correct. I forgot that we had dropped those last two since they were identical to what was already on the doors and only used the six that you previously mentioned.
empireoverlandza
