M35A2
Tinkerer
I made several of these a decade ago as a one-time expedient, and darn if they did not prove to be a heck of a lot more durable than I ever expected. Witness that, although dented, they are still going strong.
The lantern is made from a beverage can. First step, enjoy the beverage. Second step, cut off the top and open a window in front using a camp knife. Third, bend a handle from a wire clothes hangar. Last, add a candle.
If the candle is tippy, add a drywall screw through the bottom. It does not seem to matter what shape candle. A tall skinny candle will drip down and once the bottom is completely filled with wax, the candles last a very long time.
The cost is basically zero, and the utility is not bad. I suppose you could leave the top and window attached as flaps; if the flaps are closed then the lantern acts as more of a heater.
