Rosco862003
I've been on the site now for quite some time, and figured I would pick now to give you the reader a little insight on my 2006 Impreza 2.5i. Alot of my friend, most of whom are into going fast, were curious why I just didn't get a WRX, or better yet an STI. My previous car was a 1993 Miata that I loved dearly, but with over 400,000 miles on the body and engine, it was showing it's age and became a money pit towards the end. When I was looking for a new car, I wanted something with decent mileage (>25mpg), a manual transmission, and something that wouldn't make my nose bleed everytime I had to pay for insurance, oh and AWD. This basically slimmed my choices down to most NA Subarus and the Suzuki SX4. I liked that the SX4 had selectable AWD and a 6 speed manual in the 2010 + models. However, Suzuki's withdrawal from the US made me reluctant to pursue this model and so I started looking at Subarus. I eventually found a low mileage, Aspen white, Impreza with a 5 speed about 2.5 hours away in Asheville. I took a half day at work, filled up a buddies gas tank and rode with him to check the car out. Everything seemed to check out minus a little oil spotting on the plastic undertray which I was told was a little extra oil from the fresh oil change and cam seal it had just gotten. I paid the man his money and drove the 2.5 hours back to Charlotte with a smile on my face, and the faint hint of burning oil filling my nostrils. After having my cam, crank and oil pan seals replaced (previous owner paid the tab) the car still leaked oil all over the headers, which made quite the smoke show at stop lights. After hunting the issue down (oil pressure switch) I researched the install and found that a lot of people botch the job by over tightening the iron sensor and cracking the aluminum head. I figured that I didn't want to run the risk of doing just that and took it to a shop that would fix the problem if they messed it up. I took it to Motion lab, a local Subaru tuner here in Charlotte and had them replace it, only to be told that my head was already cracked from where someone tried to replace it earlier. The fix? $2000 worth of parts and labor that would include a new head, timing belt and all the seals that I just had replaced. This was all done in April, or about the same time that Uncle Sam had his hand out asking for money. Needless to say i wasn't very happy with how things played out. I thought about selling the car, and just getting something cheap that didn't require payments, but at the end of the day I spent a considerable amount of time deciding on this little Subaru of mine and I wasn't going to give up on it. So I paid the money and 3 weeks later had a car that wouldn't smoke like a chimney at stop lights. About 4 months ago I went to the Asheville area to do some camping and noticed that my engine was missing, minor at first then got worse later. The car was throwing a misfire code on cylinder 4 which apparently is the problem cylinder on STI's and WRX's. This was not good news and after about a week of combing the interwebs for answers, the conclusion I came to was that it could be anything... I decided to start off small and change the plugs, which luckily enough for me cured Fiennes! However, when changing the plugs I noticed that the wires on the passenger bank were soaked with oil, YAY! After talking to a mechanic buddy, he assured me that it was simply spark plug seals, and to come over with some beer, spark plg and valve cover seals and that we would remedy the problem. Sure enough my car no longer marks it's territory anymore.
I'm sure a few of you are curious as to why I named the car Fiennes,so will say that I was inspired by the man's tenacity and will to keep pushing boundaries, even though he's the least likely candidate to do so. He's old, he's missing a finger has been told to take it easy on his heart, and ran marathons in lieu of this advice. Much like Ranulph Fiennes my car isn't a likely candidate to take me to some of the places it has, it doesn't have locked diffs, it doesn't have an array of lighting that can be seen from the space station, it has around 5" of clearance and has had a cylinder head replaced with under 80k on the clock. However, it has always taken me to where I needed to go, has never left me stranded anywhere and just keeps asking for more all the while returning impressive mileage.
What's been done so far:
-WRX front rotors w/ Stoptech pads
-H6 rear rotor upgrade w/ Stoptech pads
-Outback 18 mm rear swaybar
-Curt Trailer 2000 lb hitch
-New Cylinder head with gaskets and Timing belt around 15k miles ago.
-Painted headlights black
-Painted Rims gunmetal
-Rear Subframe lockdown kit
-STI catback (no power gains, just wanted a cleaner looking rear)...come to think of it they make TP for that, no matter.
Best mod so far:
-A full gas tank to actually get me places.
Plans:
-Skidplates (engine, and rear diff) I've never hit anything, but I imagine I don't want to be in a situation thinking, "Hmm, that skidplate would've been really nice."
-215/60 R16 Yoko Geolanders, the smallest all terrain that fits my car on stock wheels, with no other modifications.
-2004 STI springs and corresponding KYB GR-2 struts, with possible 1" spacer kit. Already have the STI springs so I may as well use them.
-Bushings, and more bushings. I love the feel of a tight and well sorted vehicle.
-Sprintbooster: this is said to help eliminate the laggy throttle feeling that plagues earlier drive by wire throttle systems.
-I would love to have more rear lighting and will find a way to mount some clean LED's in the rear to aid backing up when I've exceeded my cars capabilities.
I'm sure that list will grow as I travel farther away and explore more of what the car can and can't do. But I think it does so well because I respect the car's abilities and don't push it hard often..often is the key word, and when I do push it keeps on going. If any Subaru owners out there have some helpful advice on what areas these cars can be improved I'd love to hear from ya! BTW, I'm not sure how many people are in the Southeast but I'll be volunteering at the Sandblast Rally Feb.28-March 2nd in Cheraw, SC, and plan on camping out there. It'd be nice to see some members out there and although this forum is about long distance travel and self sufficiency, I'm sure not too many of you would throw up a complaint to seeing some cars screaming sideways at 60 mph down a gravel road. I'll post some pictures of said event once it comes around to it, but until then here are some pictures of my car.
Best mod so far:
Plans:
