Fire Truck Box Size 1300 DOKA
There really aren't any typical sizes and it depends on the cab. There are three common Doka cabs for fire engines. First is a sort king cab type where the rear doors are relatively small and narrow. The next size is the standard Mercedes Spec Doka and the next size is the larger 9 person double cab. All have different lengths and hence the backs are all very different in size. Furthermore, it matter ifs the vehicle is a rescue vehicle, a tanker etc. For the most part the backs are custom made, so the sizes can vary quite a bit.
However, as a very rough guide line, they are generally 2.2 to 2.3 meters wide, less than 2 meters tall and length is from 2.5 to 3.5 meters long.
I can measure ours for you if you need but i also am not sure if there is a typical. are you looking to buy a box or transfer to another chassis? we are selling ours, if you are interested.
For sale:
Box/body from 1990 Unimog 1550L Doka. Selling the rear body/utility box. 2000L tank, PTO driven pump, multiple brass Storz-like connection hose fittings along with many other brass valves. Body has steel frame and skin, with aluminum 5-bar overlay (similar to diamond plating). Roller shutter doors work great and middle/main compartment has very cool aluminum pegboard that slides between both sides for convenient bilateral access. Can provide many more photos upon request. Body is in excellent condition. No rust whatsoever. Vehicle has 40k original kms and was Swedish rescue truck imported last summer. Possibility of delivery. Located in Cleveland, Ohio.
Wolfbox
