BajaTaco
Swashbuckler
OK, until this vehicle gets its own forum section, I'll put the discussion here.
I'm sure many of you may have seen the new pictures and info coming from recent coverage at the SEMA show 2005. They had a blue FJ cruiser at the show outfitted with some key things that most serious 4wd enthusiasts definitely took note of:
Fuel economy aside, the car seems to have a very solid foundation and capability in stock form, and will surely be quite capable on the trail with the addition of some key aftermarket (or possibly factory?) options. It is looking to me like the FJC is pretty much going to hit the ground running, with a large aftermarket already in development, and available quickly after its introduction to the public market. This appeals to me. The thought of having something fresh and fun from Toyota is also very appealing to me. One of the biggest factors is having the Toyota reliability in a new vehicle that is actually trail-worthy. That could end up being the sole reason for getting one (for me anyway). My biggest concerns at this point are the following:
OK, since that won't happen, maybe when the time comes, I'll just get an FJC and put a tent on the roof and call it good. :smilies27 It just looks too fun to pass up.
Thanks to mountainpete for providing us with this info:
From Truck Trend Magazine...
2007 Toyota FJ Cruiser
General
Location of final assembly Tahara, Japan
Body style 2-door, 5-pass SUV
EPA size class Light truck (midsize SUV)
Drivetrain layout Front engine, 4WD
Airbags Dual front, side, head
Powertrain
Engine type 90° V-6, alum block/heads
Bore x stroke, in 3.70 x 3.74
Displacement, ci/L 241/4.0
Compression ratio 10.0:1
Valve gear DOHC, 4 valves/cyl
Fuel induction Multipoint
SAE horsepower, hp @ rpm 245 @ 5200
SAE torque, lb-ft @ rpm 282 @ 3800
Transmission type Six-speed manual
1st 4.17:1
2nd 2.19:1
3rd 1.49:1
4th 1.19:1
5th 1.00:1
6th 0.85:1
Reverse 3.61:1
Axle ratio 3.73:1
Final-drive ratio 3.17:1
Low-range ratio 2.57:1
Crawl ratio (1st x axle gears x low) 40:1
Recommended fuel Premium unleaded
Dimensions/Capacities
Wheelbase, in 105.9
Length, in 177.6
Width, in 74.6
Height, in 70.9
Ground clearance, in 9.6
Base curb weight, lb 3800 (est)
Payload capacity, lb 1000 (est)
GVWR, lb 5000
GCWR, lb 8800
Towing capacity, lb 5000
Fuel capacity, gal 20.0
Chassis
Suspension, f/r IFS, coil spring/solid axle, four-link, coil spring
Steering type Power-assist rack-and-pinion
Ratio 15.6:1
Wheels 17.0x7 cast aluminum
Tires 265/70R17 BFGoodrich All-Terrain T/A
Load rating C
Speed rating 121/118
Price
Base price $22,000 (est)
Fully optioned price $27,000 (est)
- 33" Tires w/beadlock wheels (and they don't look like 17" either!)
- Donahoe coilovers (front)
- ARB Bull bar
- Warn Winch(es)
- ARB Front air locker
- Vertical spare tire mount (had been slanted)
- Jerry can mount
- Functional roof rack with lights and recovery equip.
- On-board air (CO2 tank + ARB compressor)
- Payload is only 1,000 lbs. As I have said before, this is often a trade-off for hard-body, wagon type 4wds whereby so much payload is used for extra sheetmetal, steel, glass, and various materials that contribute a great deal to GVW.
- Short wheelbase. It seems to me that the potential for making a viable sleeping quarters for two people in this vehicle is pretty much out of the question. If the front passenger seat was removed, I'm sure it would do ok for a single person. This leaves the option of a roof tent, which I might just have to consider if I were to get serious about buying an FJC. [Edit: After inspecting the FJ in person, I discovered it will indeed be possible to sleep inside the vehcile if the rear seats are removed and a platform is constructed.]
- Related to the above - I wonder if there would be any room below for a larger fuel tank, or an auxiliary tank. The jerry can is nice, but it would be good to keep the weight off of the back of the car and have more reserve than 5 gallons. [Edit: After inspecting the FJ in person, I discovered there is plenty of room for an auxiliary fuel tank just behind the rear axle, under the body.]
- Visibility. It seems to me that this car has poor visibility for the driver, but until I get inside and try it out I won't know for sure. [Edit: After inspecting the FJ in person, and being used to driving a truck with a camper shell and tinted windows, the use of the FJ's ample side mirrors (augmented with a couple of small circular fish-eye mirrors) makes this a non-issue for me. I would say that forward visibility over the hood is bit less than desireable.]
General
Powertrain
1st 4.17:1
2nd 2.19:1
3rd 1.49:1
4th 1.19:1
5th 1.00:1
6th 0.85:1
Reverse 3.61:1
Axle ratio 3.73:1
Wheelbase, in 105.9
Length, in 177.6
Width, in 74.6
Height, in 70.9
GVWR, lb 5000
GCWR, lb 8800
Chassis
Ratio 15.6:1
Load rating C
Price
