I could see that, either way it is rigged. That model would have had a manual lever on the dash for high-low and a cable that operated the 2-4WD via a vacuum system mounted under the hood and on the front drive of the t-case.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
