So today with the light rain we are getting I decided to go ahead and grease all the Drive Shafts/Slip Joints and U-Joints. Well I was on the second slip joint and as I was pressing grease In I noticed it was coming out up by the U-Joint and not at the slip joint seal.....
So looks like after removing all the crud and feeling around with my finger a plug of some sort is starting to come out?
So im pretty sure I will have to drop that shaft and rebuild it, and of course rebuild the other as well with new U-Joints. what all do I need for parts to rebuild these things? and are the parts available through Toyota or better places?
I will start digging into the FSM and see what I can find, but figured id get some input here as well
I went back out and cleaned it up so I and you could see it, was under the normal 1/2" of crud
