FJ60 with 261K on the clock. Trying to sort out major issues.
I learned a lot studying the forums but haven't come across anything to help me.
Issue that I'm trying to sort out: There is a loud spinning metal/grinding noise coming from what appears to be the front of the transmission. I removed the shifter boot to help listen.
Details: In neutral there is no noise. Clutch pedal feels normal and truck goes into all gears very smoothly. Transmission pulls hard in every gear and doesn't come out of gear on it's own.
In gears 1-3 there is very little to no noise. In 4th gear it gets very loud, especially under power. In any speed and with the tranny in any gear I can push the clutch in and the sound immediately goes away. This has me thinking that it is the throwout bearing and I need to install a new slave cylinder.
Do you guys think I'm on the right track?
