MountainD
We bought a Fleetwood Neon at the beginning of the summer and now that we are moving into winter, I am going to get to work modifying it for more off-road use to tow behind our Land Rover D90. I am going to add softer springs and a new axle with 10" brakes and wheel adapters to the rover pattern (5 x 6.5") and run my 33's on it. It will be using an articulating hitch.
My question is in regards to the frame. The current frame is in great shape and I put a fresh coat of paint on it after I bought it-- It just isnt a very strong frame intended for off road trails. I am debating between 2 choices--
Option 1 is to build a new frame and swap the box onto it which will be very labor intensive to disassemble the box and the roof lifting mechanism in order to accomplish this. Totally doable, just not sure that it is entirely necessary. The plus side is that would be able to strengthen the box for off road labors...
Option2 (which I prefer) is to build a new frame, cut the tongue off the existing frame, and place the box and frame right on top of the new frame and weld it onto it. This is the direction I am preferring to take, but I thought I would get some feedback on if this is a good or bad idea or pitfalls that I should look out for. I would then stengthen the box in some key places (which if any of you have feedback on, it would be greatly appreciated).
Here is the current set up.
