Flojet water pump 4105-501
nwoods
Kevin, I'm interested. I still need to do some homework first though. What prompted you to buy this initially, and why are you not using it now? I am in the process of acquiring a trailer with a 20 gallon tank on board, and am looking into options like this.
kellymoe
Nathan,
I bought is a replacement for the pump I have now which is still running strong. I realised It would be a while before the old one gives out and I am working on another idea now and wont be needing the pump. I will probably be going toward a hand pump type system in the future as a back up.
vanderpooch
Authentic Adventurer
Is the rate at wich the water pumps adjustable?
I am in need of a pump but concerned about rate of flow and what is a good rate. I don't need to have a 15 yrd water canon I just want enough pressure to shower and do dishes.
kellymoe
I have the same one hooked up to my truck now and it is not adjustable but is by no means a high pressure pump. I regulate it at the shower valve or faucet.
nwoods
Kevin, I am going to hold off for now. I need to tinker around with this trailer and get to know it better before I start buying stuff. Cheers,
Nathan Woods
kellymoe
Now $80 includes shipping. Come on someone must be building a water system for their vehicle. Someone buy it.
Scott_sFZJ80
Hello, Does this unit have a pressure switch that allows it to turn on and off? Or is it a constant flow of water?
Thanks, Scott
Clemtiger84
