For Sale: 2015 Ford F-250 Lariat FX4 with 2015 Northstar 850SC
Dustyroad
This is like a brand new fully loaded Ford F-250 Diesel pickup with 7,250 miles. It still has new car smell. Options:
Leather Seats
Sunroof/Moonroof
Navigation System
Preferred Equipment Package
Chrome Wheels
Bluetooth
Memory Package
Backup Camera
Remote Start
Off Road Package
Tow Package
Ultimate Package
The standard FX4 fake Rancho shocks have been replaced with Procomp Pro runner monotube shocks. The stock single steering stabilizer has been upgraded with Procomp Pro dual steering stabilizers. Also rear Firestone Heavy duty airbags have been added to help stabilize a heavy load.It has Torklift Tie Downs and is ready for a Truck Camper.
The camper is a like new 2015 Northstar 850SC, only used 3 times.
Specifications
Base Dry Weight (pounds) 1,735
Closed Body Height 5' 6"
Interior Height - Open 6' 8"
Interior Height - Closed 4' 8 "
Exterior Width 7'
Overall Length 15'
Floor Length 8' 6"
Approximate Center of Gravity
(measured from front of truck bed toward rear) 32"
Cabover Bed Size 60" x 80"
Dinette Bed Size 36" x 73"
Mattress to Roof Height - Open 29"
Mattress to Roof Height - Closed 4"
Fresh Water Tank (gallons) 30
Gray Water Holding Tank (gallons) 13
Cassette Fresh Water Tank (gallons) 4
Cassette Black Water Tank (gallons) 5
Features
Dometic 3.7 C.F. 3 way refrigerator 12,000 BTU Auto ignition furnace w/ digital thermostat
4 Corner mechanical jacks 2 Burner stove
Single sink w/ single lever faucet w/ pull out sprayer Auto ignition water heater w/ exterior port shower & bypass
30 Gallon fresh water tank City water inlet
Marine grade ultra light plywood Hand fitted block foam insulation
Insulated floor Fiberglass siding with graphics
7-way plug with holder 30 amp power cord with adapter
25 amp power converter/charger LPG, CO & Smoke detectors
20 lb stand up exchangeable LPG tank Pop out pass thru window
Tinted radius crank out dinette window Slider galley window with screen
Screened entrance door w/ dead bolt & gas strut "SureSleep" 6" foam mattress 60" x 80"
Front rubber bumpers Interior shower with cassette toilet
13 Gallon gray water holding tank Fire extinguisher
Interior vented plastic battery box-Group 27 Interior & exterior 110v outlets
12v Utility receptacle Fantastic Fan with thermostat
LED interior & patio (3) lighting Large folding assist handle
Lagun swing away table system Battery shut off switch
Lift up cabover bed with 2 gas struts 1/2 Wrap around rear end w/ LED lights
Quad Torsion lift system North/South extended cabover with side cabinets
Add on accessories
Roof Air conditioner with heat strip, Cable TV inlet, Pre wire for electric jacks, Double sink, 5 Step aluminum scissor step, all weather camper cover.
The Truck w/o Camper $52,500
Camper w/o Truck $17,900
Package Deal $67,000
ELShockley
