Ozrockrat
OK Guys
The Ambo is a dog. Looks like the max boost I am getting is about 8 PSI and then it goes downhill quickly.
Original problem was it would be OK (no real power but it drove OK) until it warmed up then there would be a big puff of smoke under the doghouse as one of the up-pipe gaskets let go. I managed to do a boodge repair on that as the up-pipe was scored along the pipe where the gasket runs (Ford/International what the hell were you thinking). While testing that I also dropped the exhaust before the CAT to try and rule out a blockage on the exhaust. Air filters are clean and there are no obstructions in the air inlet and no visible leaks on the compressed side.
So that one is fixed but some of the same symptoms are there. Surging, Power tapers off(actually drops off). No real get up and go.
Here is a recording of the Boost, Exhaust Back Pressure, Throttle Position and Engine RPM. It is easy to see that the boost is only getting to 8 PSI and the back pressure is fairly stable for the boost that is there.
Any suggestions before I pull the turbo and up-pipe. (Up-pipes will be replaced but I want to do something about the design before I put new ones in). (Also I am heading off to do a border to border run. AZ to Vancouver in two weeks :Wow1![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![i-vpRPZKn-X2.jpg](http://aussieinaz.smugmug.com/photos/i-vpRPZKn/0/X2/i-vpRPZKn-X2.jpg)
