FORD E250, 2012 RB 5.4L 13k miles, 2WD (New and very custom) $75K
Jim Hefner
Though this looks like a Sportsmobile it is far from it. This rig was designed by me and assembled by craftsmen; it’s a one-off and was not produced on an assembly line of marginally skilled labor. It is one-of-a-kind and a work of art. Every single person that’s seen it and understands quality of design and build is blown away. If you’re looking for a new, unique, and super trick rig, this is the one. I’m selling it because I finished building it 2 years ago and it just sits in my driveway. Given my work schedule is not likely to change for the next 2 years I’m gonna sell it as it simply makes me sad to see it sitting unused. The low miles are 99% freeway. I’ve camped in it like 5 times. Basically it’s flawless.
2012 Ford E250 5.4L 13k miles, 2WD (brand new and very custom)
“RB 50” style
Sportsmobile Penthouse pop-top (manual) Completely overhauled. Top was removed, re-insulated, re-sheeted w/ ¼” marine ply, quality felt liner, added improved stainless bolts/nuts
Bamboo cabinets, drawers, and countertop. Built by cabinet makers. Bamboo is light, beautiful, and very hard
Action Van 6” lift (their Ultimate System)
Steering stabilizer (Bilstein), fender flares, and steps
4.10 Limited slip differential (Dana)
Deaver leaf springs (custom)
Fox Shocks (custom)
Ford E250 Tow package (includes hitch, large radiator, and high-amp alternator) have never towed anything though
Nitto Terra Grappler Tires 285/75R 16
Wheels American Racing AR23
Solar panels - 2 - 140 watt Kyocera
Fiamma awning 10’ with custom mounting brackets
Awning also has chassis mounting points for legs (not on sheet metal)
Golight spotlight on roof w/ cockpit control
Suburban 5 gal hot water heater
Truckfridge 4.2 cu. ft. 12v
Propex heater with thermostat (HS2800 w/ 9,700 BTU) behind driver seat
Stove - SMEV 8000 2-burner w/ lid
25 gallon fresh water holding tank
Insulated stainless sink with pullout faucet
GE 2-stage water filter under sink
Microwave
Charge controller
Inverter panel
LED touch to click on lights throughout
Inverter - Xantrax 2000w Pure Sine
7 gal Manchester propane tank
4 gal gray water holding tank (mounted under rig to save storage behind cabinets)
2 AGM Batteries stradling under floor storage box (where spare used to be)
Front buckets swivel and electric heat
Aluminess rear bumper with large box and spare tire mount on swing arms. Also, Yakima mounts and back-up lights
Upholstery Ultraleather (synthetic) throughout
Dynamat throughout floor and sidewalls
Extra insulation in floor and sidewalls
Floor also has ½” foam/vinyl (MLV) covered in Lonseal rubber floor
½” Marine grade plywood under Lonseal
Alarm - Encore E9 2-way
JVC head unit
JL Audio XD600/6 (600 watt amp)
JL 8” Sub woofer
5 - Kenwood Excelon 6” x 8” speakers
Custom Tweeters in A-pillars of doors
Starlights exterior motion porch lights w/ LED bulbs X2
Tinted windows
Fire extinguisher
SureFlo water pump
Full set of tools, recovery kit, VIAR compressor, water hose, outdoor carpet, etc.
I live in the Los Angeles area.
***Huge price drop. $75,000 ***
Jim Hefner
more pics
Jim Hefner
and more
Jim Hefner
more
iStan814
