Ford F250 & Northstar TC650
I ordered the cabinet directly from Northstar. Installation went well, not to hard as long as you have a helper to hold the cabinet in place. You do have to assemble the cabinet doors and latch.
Thanks coulter6. Assembly required is no problem. How is the cabinet attached to the ceiling? Are there solid supports to anchor it to?
I too have a NS TC-800 that I am replacing the two fixed post table legs with a Lagun mount. This is the 4' table top.
Question... Where exactly should the Lagun mounting plates be installed? Both table top plate and wall plate.
Found a couple pics online that seem to indicate the wall plate is not center and have no idea where the table top plate is attached.
Looking for measurements for optimal swing.
Gonna do that wine bottle mod next...Thanks!
BurtC,
I sold the camper, so I have no measurements to give you.
I centered the table mount on the side wall. I believe the table bracket was offset a bit from center of the table top, but I'm not certain.
Of course, there are dimensional differences between the TC650 and TC800 that may affect your installation.
I'd recommend clamping the table top to the bracket and try different locations.
The picture of the Lagun table on the TC800 page of Northstar Campers website looks centered to me. I'd start there. You can also call Northstar directly and someone can probably talk you through the installation.
Good lock with your Lagun table. It's a real step up from the original table system.
I concluded that the only place I could easily access to place the mount was the rear inner corner of the dinette accessed via the storage space under the rear seat. If the camper was off the truck mounting it on the side wall of the dinette would be possible. Not sure which is best. Where does Northstar mount it? I reinforced the rear panel with a piece of plywood before bolting the mount thru it. Very happy with the mount though. Far better than the original post.
Camp Tonneau Tents
